Raptor 60 v2
IL
RE: Raptor 60 v2
I'm willing to bet the clutch is touching the clutch shoe. Loosen the bolts on the engine and let it slide down about 1/4" and see if the blades spin freely.
IL
RE: Raptor 60 v2
I found that the engine washer syndrome applies the OS70 setup also, in turn that drop the clutch down a bit as if I lowered engine for clearance. I also discovered that the fan assembly easily comes loose, so use plenty of lock-tight.
