Vibrating tail ?
My Feedback: (117)
Vibrating tail ?
Does or did anyone have a problem with a Vibrating tail on their Raptor 60/90? I discovered that the "white" tail gear is out of concentric and I believe that is causing the vibration, anyone have that problem?
CA
Vibrating tail ?
i have noticed the white tail gear being not 100% perfect, slightly damaging the counter gear, i stopped replacing them, since it does not help.
but i do not have any vibrations either, just a little nervous about loosing the tail... would be great if they would come out with some metal gear upgrade...
NY
Vibrating tail ?
I had an Excell 46 G awhile ago that had a vibration in the tail, I found the tail boom struts were loose, tightened them up, vibration was gone. Just a thought.....Coop
My Feedback: (14)
AL
Vibrating tail ?
I had this problem on an Ergo 46, I replaced everything ouput shaft balanced everything as an assy. no luck. It turned out to be the rough mids on the older OS 46, due to the carb on it. I upgraded to a newer part # carb body and it 100% fixed the issue. I was ready to buy a new OS 50 by this time though.
RE: Vibrating tail ?
HI
PLEASE HELP ME,I DONT KNOW WHAT TO DO
I HAVE A RAPTOR MINI TITAN 325SE.
I HAVE VIBRATION IN ALL THE HELI, WHEN MORE RPM MORE VIBRATION.
I CHANGE THE MAIN GEARS, MAIN SHAFT, SPINDLE, I BALANCED MAIN AND TAIL BLADES,THE TRAKING IS GOOD, I CHANGE THE MAIN SHAFT BEARINGS. AND NOTHING WORKS
I TAKE OFF THE TAIL, AND GYRO, AND SUPPORT THE HELI IN MY HANDS
AND IT CONTINUE VIBTATING, SO I THING IS NOT THE TAIL.
BUT I DONT KNOW WHAT ELSE TO DO.
I SEE THE SWASHPLATE AND IT HAS A LITTLE BACK AND FORTH MOVIMENT, BUT THE MAIN SHAFT IS NEW AND I CHECK IT ROLLING OVER A GLASS AND IT IS OK.
WHAT ELSE I CAN DO?
I WILL APPRECIATE YOUR HELP
THANK YOU
WHAT ELSE I CAN DO?
THANK YOU
