picth setup
picth setup
hi there i have a raptor 50v2 and jr9xpcm version 11 transmitter
i can fly around in figure o eight and now what to set up for 3d miy picth is bottom sick 2 mid stick 7 top stick 12do i have to change the rod lenghts to get the negative picth in flight mode st-1 or is it all done in the radio can some one help me please
RE: picth setup
First thing you need to do is set your mid stick to 50% in the radio. Then adjust the blades to get 0° pitch at mid stick. From there you should be able to adjust the rest of the pitch range in the radio. You will also need to readjust the setting in normal after you adjust the blades linkage.
RE: picth setup
http://www.raptortechnique.com
Set the heli up for symetrical pitch throw mechanically with a pitch curve of 0 to 100 and 50 being zero degrees at mid stick. Then use your radio to setup your curves for flying.
AL
RE: picth setup
Motions:: ... First thing you need to do is set your mid stick to 50% in the radio. Then adjust the blades to get 0° pitch at mid stick.
Good Luck,
d.tipton
