Governor and Field Charger
My Feedback: (35)
Hello,
When its windy and when i turn the my raptor 30 in the turns it goes up or goes down depending on the direction of the turn, its normal because the main rotor speed reduces and increases and it has to be compensated by throttle.
One of the guy suggested me to get a governor to overcome that problem. Does a governor help in this regard?
I am not into 3D stuff i am just learning forward flighht. Is it worth to get a governor at this stage or its completely waste of money? If i need to get one which is a good one, i use Futaba 9c with PCM servos (S9001), GY401 + 9254, Futaba R1490P reciever and OS .32 engine.
One more thing what field charger do you guys recommend? I use a 12 V battery for my starter.
Please advise
Please advise
RE: Governor and Field Charger
http://ks.jp.org/ks_e/index2.htm
I re-charge my 1500mAH nicad after every third flight.
As for the governor, I have been flying around a year and I just installed one. I tend to agree with barracuda, plus it is a good idea for you to have good experience at setting up throttle curves. Just because you fit a governor does not mean that you can just fly without setting up a backup throttle curve.
In addition, getting a governor (in my case a GV-1) set up is far easier once you are competent and comfortable in flying hover, SFF and FFF.
ND
ORIGINAL: zsultan
Hello,
Hello,
Almost any charger will do the job, but look for one that can charge all types of batterys and can cycle NiCD and NiMH batterys. My personal favorite is the Electrifly Triton avaiable from Tower Hobbies.
http://www2.towerhobbies.com/cgi-bin...&I=LXMAJ0&P=ML
