Go Back  RCU Forums > RC Helicopters > Thunder Tiger - Raptor 30, 50, 60, 90
 Raptor 50 Tail rotor pushrod clips >
Old 12-05-2009, 08:00 AM
Default Raptor 50 Tail rotor pushrod clips
I am sure I am not the only one who doesn't like that fact that the 3 boom clips " float " where ever they want to. Does anyone want to share what they do to keep them in place, ie Glue etc. etc.
Joe
Old 12-05-2009, 08:57 AM
My Feedback: (8)
Default RE: Raptor 50 Tail rotor pushrod clips
I CA glued mine in place
Old 12-05-2009, 02:24 PM
I used a piece of nylon wire tie slipped under the clip & trimmed so as not to be visible.
Old 12-25-2009, 06:19 PM
If you leave them loose you risk getting your tail control rod being stuck which would lead to some "interesting" tail action some use tie wraps stuck under the guides, some ca them. Tired both, prefer ca but you really need to use only a drop. Anything more and it will be a pain to get off...
Old 12-25-2009, 10:17 PM
My Feedback: (8)
I use CA, works great, AND I like how easy they slide off the boom for maintenance.
Old 12-26-2009, 11:44 AM
BarracudaHockey's Avatar
CA is the ticket
Old 12-27-2009, 07:42 AM
On my Raptor#2 I use bathroom silicon sealant. It sticks them in place well, but does not cause embrittlement. Easy to remove too.
JR make a very nice boom tail rod guide That are adjustable and are easily clamped in place with cable ties.
http://www.gohobbies.com/itemJRP-960293.html
The pic shows them unfolded, they wrap around the tail boom. Far better than the TT ones.
But, I much prefer using a boom mounted tail servo (Raptor #1) that doesn't need them.
Old 12-29-2009, 08:43 PM
I small plasitc zip ties to hold mine in place. I use one tie in front of the guide, and one tie behind. Quick and simple. This keeps them from sliding up/down the boom. The tail rotor pushrod keeps the guids from rotating around the boom and allows the guids to find the position that causes the least amount of friction on the TR rod.
I'm not doing anything wild flight wise, so I'm not sure if this set up would be ok if I were doing crazy 3D. No problems thus far with basic aerobatcis - flips, rolls, loops, piro's etc.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
