Retract Question
I have a set of retracts that are not as smooth as I like. I think this will do the job:
http://dreamworksrc.com/catalog/thin...ngs-p-810.html
I wanted to see if regular 3 in 1 oil is simliar and safe to inject into retracts or do I need to by the lubricate listed above?
Any help is appreciated.
Mike
Mike
I think that regular 3-in-1 oil would probably make the o-rings swell and bind in the cylinders. I would check with an air cylinder supplier to see what they recommend.
Air tool oil is made for tools using the black buna-n o rings. Paintball gun oil is pretty similar stuff too if there's a store near you that has it.
