 Air Pump recommendations needed >
Old 11-20-2012 | 10:29 AM
sparky4lawndart's Avatar
My Feedback: (10)
Default Air Pump recommendations needed
Gents... I'm giving up on electric retracts as I blew my wad on a pair of Eflite 60 120 size electric retracts that aren't working for me... I'm sending them in to be checked but I still need to fly so I put in the Robart air retracts that came with the kit...
They are installed... I tried pumping it up with my kids bicycle pump and it took a minute to get to 40 lbs... (weak pump)...
the guys at the field have cordless ones... I much prefer the "press button" instead of throwing out my shoulder... what are you using... where can i get it... The one at Sears (19.2 v lithium ion deal is $50 plus $30 for the battery plus $30 for the charger) too much!
I do have a harbor freight 15 minutes away but wanted details first...
thanks
Old 11-20-2012 | 12:03 PM
Taurus Flyer's Avatar
Default RE: Air Pump recommendations needed
ORIGINAL: sparky4lawndart
the guys at the field have cordless ones... I much prefer the ''press button'' instead of throwing out my shoulder... what are you using... where can i get it... The one at Sears (19.2 v lithium ion deal is $50 plus $30 for the battery plus $30 for the charger) too much!
thanks
Wrong.......... , you use the wrong part of your body!
Shoulder, arms, hands and thumbs are important to control your airplane, so what is left?
See the photograph.
TF
ID:	1822083   Click image for larger version
Old 11-20-2012 | 12:16 PM
Indeed, your feet.
Two a three strokes on that pump is enough for my pneumatic retracts.
TF
Old 11-20-2012 | 12:18 PM
My Feedback: (10)
Taurus.. buddy.. pal... where'd you get that foot pump???
Old 11-20-2012 | 12:43 PM
Sparky , I did pay about one or two Euro on a swap meet in the Netherlands, but also in a shop these aren't expensive.
You can find these with one or two cilinders, one is enough.
I use a standard bike/care "valve", (checkvalve?) near the wingbolts of my Orion to connect the pump.
TF
ID:	1822092   Click image for larger version
ID:	1822093   Click image for larger version
Old 11-20-2012 | 02:48 PM
Live Wire's Avatar
I picked up a Fuel 250 psi/12volt at wallie world tire department works great.
and it only cost around 12 bucks
Old 11-21-2012 | 06:14 AM
http://www.harborfreight.com/foot-pump-37544.html
Old 11-21-2012 | 06:36 AM
AFTER SALES SERVICE!
I was warned by the reviews of the example of Zulu and measured the metal parts of the frame of my blue pump, these are all 4 mm thick, 5/32 " (4.09 mm with the blue paint!)
It is a German brand and has a German Tüv qualification.
So have attention there is difference in quality!
For us the pump hasn't much work to do, a few pushes to start and after a flight I check the pressure by pushing some more air in the air capacitor, often less than one cycle.
My checkvalve does have a small ball inside so there is no 'threshold' pressure whille pressurizing the capacitor. so the Indicator pressure of the pump is capacitor pressure of the plane.
TF
Old 11-21-2012 | 04:51 PM
I have the same problem as you, I got a good quality bike pump with a gauge but it is a bugger to put 120 lb's in that cylinder. I should have thought of the foot pump, duh, I'm glad you asked, thanks.
Old 11-21-2012 | 05:52 PM
DavidAgar's Avatar
My Feedback: (108)
I got a 12 volt pump from Harbor Freight. It was on sale for $5.00 and it works great. Nice and compact and fills up my air tanks in no time. Good Luck, Dave
Old 11-22-2012 | 12:07 AM
ORIGINAL: Leroy Gardner
Redundancy
Hydraulic and pneumatic systems are used because of the rigidity and simplicity of these systems. Sometimes also forced by environmental circumstances, think about use of pneumatic systems in explosion hazard areas for example!
When you quit with electrical retracts don't let Mr Murphy enter through the back door!!!!.
So let your choice be a sandwich feeded power system of comparative solid principle and ............ have attention for redundancy.
So, thank the Lord he has equiped us with two legs you simple cannot forget to take with you because they take you with!.
Have fun!!
Taurus Flyer
Old 11-22-2012 | 07:57 AM
My Feedback: (10)
$7 dollars at Harbor Freight (10 minutes away - next door to a Walmart where I was going to buy the foot pump)... It works awesome... takes about 10 seconds to get the Robart system to 110psi..
thanks everyone...
Old 11-22-2012 | 08:33 AM
badger5964's Avatar
I got a $5-10 pump, that plugs into cig lighter, from Harbor freight. Pumps about 100 psi. I wired it to me field battery and soldered a peice to it that would allow me to use the small Robart pneumatic hose and fill adaptor. Mounted the whole contraption and a pressure guage to my field box. Works good, although I have my doubts about longevity of the pump. But then again it only comes on about 10 seconds each flight.
Scott
Old 11-22-2012 | 01:16 PM
ORIGINAL: badger5964
Scott
and a long way back home!
TF
Old 11-22-2012 | 01:46 PM
My Feedback: (10)
LOL, Taurus!!!
Is that you?
Old 11-22-2012 | 01:56 PM
No, that's Scott not knowing about Murphy, because, even the pump isn't directly wired to the car battery .................!!
He'll remember!
TF
Old 11-23-2012 | 05:33 AM
I messed around with cheap "portable" air compressors and had them give up on me. I got a compressor from the local auto parts store and it has served me well. Rechargable, truely portable (no cord to your car battery or field box) and it fills my air systems in less than a minute. It's rated for 230 PSI so at 100 PSI I am not taxing the pump. Cost not cheap at about $65.
Old 11-23-2012 | 09:21 AM
Cost not cheap at about $65. nearly 6 $/lbs.
Old 12-02-2012 | 08:03 PM
badger5964's Avatar
Here is a couple pics of the Harbor Freight air compressor. Been flying with it few months and likely five or six flights plus topping off a couple of my van tires to test the apparatus. That was likely equal to a couple seasons of flying. I had to butcher up the plastic housing some so it would fit snugly under the control panel. It is very convenient because I do not bring anything extra to the field, the black hose is about 6' long, has a Robart quick disconnect to attach to pump and a Robart fill connection to attach to plane. It is all over in about 10 seconds. No worries about explosions or pushing my car home.
ID:	1825990   Click image for larger version
ID:	1825991   Click image for larger version
Old 12-02-2012 | 08:10 PM
badger5964's Avatar
I started with the same compressor as sparky4lawndart. Never under the illusion it would do 250 psi. After use it seems to top out at 100 psi which is more than plenty to operate the Robart retracts. If it went to 250 psi I'd have to cut it off or risk it overpressurizing the can. It works fine, I just let it run until the I unscrew the hose from the plane.
