 rigging tail gear >
rigging tail gear
rigging tail gear
Old 12-10-2012 | 07:55 AM
Default rigging tail gear
Any other ways to rig a workable tailgear on a SIG kadet sr.? The rudder is pre-hinged from th MFG.
THX ==TAZZZZ
Old 12-10-2012 | 08:48 AM
Default RE: rigging tail gear
Hi!
Use an all swiveling tail wheel!
Old 12-10-2012 | 08:54 AM
Should we assume that you mean tailwheel? Or, do you have something else in mind. If you mean tailwheel, then you will have to relocate the main gear to keep the tail on the ground since the Kadet Sr. is a trike-geared plane. If you want a tailwheel, I would suggest that it should be steerable so that you have more control. You can link the tailwheel strut to the rudder to achieve that.
Old 12-10-2012 | 11:30 AM
vertical grimmace's Avatar
Run a seperate linkage to the rudder servo. Nyrod works good.
