 hatch locker >
hatch locker
hatch locker
Old 05-12-2013 | 05:40 AM
rye
My Feedback: (10)
Default hatch locker
hi
i saw on the world models 46 size 540 slick quick release hatches ,where can i get the locking device to make my own quick release hatches, thanks
Old 05-12-2013 | 11:20 AM
Default RE: hatch locker
Hi!
In pylonracing we have used something called "Dzus" fastener . It's used to secure engine cowls.
Old 05-12-2013 | 11:34 AM
rye
My Feedback: (10)
Hi
Where can I get them
Old 05-12-2013 | 07:14 PM
KitBuilder's Avatar
I use something similar to the red one...
http://www.hobby-lobby.com/hatch_latches_441_ctg.htm
they all basically have the same theme.. sliding rod held extened by a spring.
Old 05-12-2013 | 07:25 PM
It's been my experience that Dzus fasteners are used an full size aircraft and race cars. The ones I have used would be too large and require too much force to engage and disengage on a balsa model airplane in the .40-.60 size range. Maybe you could use them an very large model planes if mounted into plywood, I'am not sure. I have a box full of them left over from my race car building days but never thought about using them on my model planes. jaka, are you talking about the same size Dzus fasteners as I am? What size model planes have you used them on and how have you mounted the spring. We pop riveted them into a steel ,aluminum or fiberglass panels on a race car.
Old 05-13-2013 | 04:44 AM
Hi!
I have small Dzus fasteners with a head diameter of 7,8mm. These are used for securing engine cowls (glass fiber cowls) on Formula 1 or Sport .40 planes ...or what ever small plane you like. A 1,2mm piano wire is used for the DZUS to grab to
Old 05-13-2013 | 12:05 PM
aspeed's Avatar
The red one as mentioned above looks good as well as the magnetic ones used in the newer ARFs.  They need a tab or hinge on the front and latch or magnet on the back in case they come loose IMHO.
Old 05-13-2013 | 12:15 PM
Hi!
None of them are will do! I have small Dzus fasteners if you would like some. 7,8mm head and 7mm long.
Old 05-13-2013 | 08:59 PM
jaka, Thanks for the reply on the Dzus size question. Yes, the ones I have are almost twice the size of yours. Mine have an almost 16mm head and use 2mm springs. I dug out my box of left over racing Dzus fasteners to measure them and found some smaller 7mm head different style fasteners we called "jet locks" that I may be able to use on some larger models. I had forgotten just what all I had in that box till I dug it out to measure. Thanks and smooth landings to you.
Old 05-14-2013 | 07:02 PM
I still have some CAMLOC fasteners I bought from Prather Products about a 100 yrs ago when they were still in business. They're something like Dzus fasteners, just a different brand. Give it a google for a source. They make some small ones, like a 1/4 in. shank which are the ones I have..
Old 05-16-2013 | 05:43 AM
I like the Camloc fasteners, as well. Use them on my 1/4 scale L-5. Here is a link that shows several sizes:
http://www.camloc.us/camloc-quarter-turns-catalog.php
The ones I use are V26S01-*AGV. Hope this helps you.
