Piper cub glass
I have the chance to get a 1/4 balsa USA cub already built and covered, but it has no cowl or glass. I can get a cowl from fiberglass specialties but don't know where to get the glass. Balsa USA doesn't sell it. Any idea?
jerry. [email protected]
As aserc suggested, flat plastic can be used to make the glass". I used black vinyl to make the "glass" on my Coroplast 71" WS J3Cub. You could do the same by gluing in place 1/32" plywood that are covered with vinyl.
The plans have a patt for cutting out the windshield . If you don't have a set of plans BUSA will probably forward a patt if you call them . The side windows you should be able to copy onto a piece of paper from the frame of your Cub .. Good luck
