Tile Saw as a Table Saw?
Hi Group!
I need a small table saw for modeling, and am looking at taking a used tile saw (Rigid R4020 7") off of Ebay, and putting a high tooth count wood blade on it.
Should there be any problem with this?
Thanks!
Mike
Thanks!
Mike
My question would be, "Why do you need a table saw?" I've been building R/C planes for some years now, some scratch and some kits. I have a full woodworking shop with a nice table saw, but I never use it for building models. I would, however, be lost without my band saw.
Rick
Rick
I made some motor mounts from a piece of maple flooring. It gave me a lot of parts. I used it to make a fixture for line reels for control lines. Really that is all I used it for in about 15 years. I don't do a lot of building any more, mostly repairing and swap meet patch jobs. I am having a garage sale this weekend and deciding if I should keep the circular saw. I don't use it much even for household stuff, but think I will keep it anyway.
I know we all want to conserve space, but you KNOW as soon as you let that bad boy go, you're going to have a project come up where you need it. Now if you're just looking for an excuse to buy a new one..... well, we all understand that too.
The problem with using tile saws most the arbor and motor shaft are one and the same. End play can be excessive for use as a table saw. For instance ripping something and having the arbor/blade move in and out will result in a rough cut with lots of splintering from the upcut or trailing edge of the blade. Most tile saws just dont cut it as a table saw conversion. If you can find a Dremel it is the cheapest way to go. http://www.ebay.com/bhp/dremel-table-saw
Dennis
Dennis
My Feedback: (158)
I'd been thinking it would be nice to have a small saw downstairs, sometimes I just need to rip some strips and to go up and use the Delta Unisaw is way overkill, especially if its cluttered.
I have one of these that had a bad switch (stays on), anyway I bought a new one for work, I think I'll build a small shop table with it.
