Custom Woodcraft Flight Box  - foam padding replacement >
Old 09-27-2017 | 07:40 PM
Default Custom Woodcraft Flight Box - foam padding replacement
I have found a foam padding that is virtually an exact replacement for the original. I searched high and low for a padding that would fit in the cradle slots. The supplier is threeriverssupply.com and it is windlace round rubber with kraft, part # 1/2 RWK. Their phone is 412-461-2156. These flight boxes are great when you happen to be flying at a field without tables and benches.
Old 09-28-2017 | 06:27 AM
rgburrill's Avatar
I bought some cheap pipe insulation from Home Depot to replace worn-out cradle foam.
Old 09-29-2017 | 03:37 AM
TomCrump's Avatar
That's what I use, too.
Old 09-30-2017 | 02:22 PM
tailskid's Avatar
My Feedback: (34)
Thanks Tiger Moth....you gotta love that toolsbox!
Old 10-02-2017 | 06:17 AM
Also thanks to T.Moth. I've had the box for years, and was searching for the windlace also for a long time. Got close on many occasion, but, now to your efforts I will be able to replace the old, cracked sponge rubber.
Old 10-02-2017 | 01:27 PM
I look at these boxes as functional art. The thought that went into designing the adjustable top cradle is is ingenious. I just wanted to keep it as original as possible. I don't know how many variations on the interior were made. I have seen a couple. Mine has the center section with drawers and the tote at the bottom and then the right section is all drawers and the left side open. I looked for a while before I found this one. If you are into vintage R/C, you can't beat it.
Old 11-11-2020 | 11:41 AM
Default flite box foam
this product is no longer available from threeriversupply. it has been discontinued. if any body purchased more than they need i would be interested in buying
