Crankshaft removal
I need advise on removing the crankshaft from an OS 70 Surpass. The engine has sat idle for a long time. I have everything removed from the crankcase but the crankshaft does not want to slip out of the bearings. Do I need a press? Thanks
Put the nut back on the crank so it's flush with the tip, and you won't risk any damage to the threads.
That's also a chicken dinner or baking a cake at 350F. Even a thin crust pizza falls into that range as well. I'm sure 250F will do it, although stubborn engines sometimes see a propane torch, especially if you don't want that engine taste on your bagels the next morning, 350F is a lot less than a propane flame.
