glue for Canopy >
glue for Canopy
glue for Canopy
Old 04-28-2023 | 08:01 AM
Default glue for Canopy
I have a glow plane that something fell and cracked canopy. is there a glue i can use to clue crack to keep crack from running or cracking more from pressure from flying?
Old 04-28-2023 | 08:22 AM
I use the clear tape that's sold for use on packages for mailing. It doesn't look great, but neither will any sort of glue.
Old 04-28-2023 | 11:37 AM
Outrider6's Avatar
A technique on other materials is to drill a very small hole at the end of the crack. That tends to stop the crack from getting longer.
For gluing canopies to airframes in new construction, RC-56 Canopy Glue or Weldbond work great. They might work, but maybe not great, on fixing a crack.
E-6000 is like a thinner version of Shoe Goo, and it is extremely handy for many things. I go through dozens of tubes each year. You can buy it at any Walmart or most any home center big box store. If the surfaces are properly cleaned, it sticks like a you-know-what, it is quite strong, and very flexible. If your canopy were mine, I would clean it very thoroughly with denatured or isopropyl alcohol, drill a 1/16" diameter hole at the end(s) of the crack(s), run a bead of E-6000 glue along the crack, then come back the next day to admire or fly it.
Old 05-03-2023 | 12:34 AM
Easy fix, laminate it from inside with a layer of fiberglass cloth or lighter Gator silk using any resin or epoxy. Sand it over from the top and repaint it any colour you like.
