Photos Of Trailer Interior Layout, Please Post Yours Too!!
#351
I've got the same backup camera system. Mine was a but more expensive at $100K. But it did come with some extras like a shower, dual air conditioners, microwave, stove, oven, sleeping beds, TV/DVD/VCR/Stereo, etc. I think Rogers is lighter than mine since mine weights in at 26,000lbs and requires 6 truck tires. It not a magnet mount either, but does feel stuck to the road while driving it.
Seriously though. With the backup monitor on my motor home, I can easily park the ball right under the hitch without ever leaving the drivers seat. I can see how useful Rogers setup would be on my mini-van.
#353
My Feedback: (7)
BTW, I don't leave the camera on the back of the van or the trailer while traveling, its only for pinning or backing up.
#356
My Feedback: (38)
Originally posted by aerografixs
Here is the setup. A tiny wireless camera that I installed in a self contained battery box with switch, pilot light and charging jack.
On magnets, easy to relocate.
Inside, a small 5" B&W TV on the dash.
http://www.x10.com/products/x10_vk45a.htm
#357
Everyone,
I would like to thank yall for the wealth of knowledge and inspiration I have received after reading this entire thread.
I am currently looking for my first trailer, either a 6x10 or 6x12 and now have the ideas to give the future transport plenty of MOJO.
BTW, when I get it setup you can bet I will post pics here!
-Dave
-Dave
#358
My Feedback: (32)
GA
My trailer
Here is a pic of my 5x8 trailer...note the heli table in the front.
http://bellsouthpwp.net/r/o/rokman/trailer.jpg
#360
Roger,
That's a nice looking setup. I am picking up a Pace 6x10 on Wednesday. On your shelving , did you use metal screws into the studs?
Bill
http://www.bp55899.com
Bill
#361
My Feedback: (7)
Originally posted by BP5589
Roger,
Bill
Roger,
Bill
The rail is screwed in the metal studs of the trailer.
#362
Just finished my trailer
Have to show you what's been soaking up my time and money. I'm transferred shortly to another city which gave me the excuse and push I needed to modify my trailer to make it a rolling hangar. It started out as a 4 X 6 with a 1 foot high box, and I had a friend stretch it to 8 feet and cut away what wasn't needed. I built the 4 X 4 X 8 foot box using spruce 1 1/2 X 1 1/2" (2 X 4s ripped in half) and plywood. Everything is glued and screwed using polyurethane construction glue. The floor is 3/4" plywood and the sides and top 3/8th" good one side. The doors are 1/2" good one side. It is on a Subaru rear axle with 13" tires. I painted it with 3 coats urethane floor and porch enamel inside and out. The underside of the floor has a coat of polyester fibreglas resin for waterproofing. It's ready to kit out for model use now. I have rails 1/2 way up to put a plywood shelf on so I can make more use of the space.
#365
My Feedback: (7)
Hey guys, after purchasing my new Haulmark trailer, I need to get rid of the other one, any ideas?
#366
Painted trailer
Now Daryl, look what you've done. After seeing the inside of your trailer (by the way, you could eat off of the floor) I'm going to have to go out and paint mine. I didn't need the extra work, but yours looks so good and so bright, I'm going to have to do it. Nice job.
#368
My Feedback: (20)
NC
The trailer looks good Daryl!
Are you going to miss draging the planes in and out of the car every time you want to go flying?
Nice job with the trailer, it will defintely cut down the hanger rash.
Doug
Doug
#369
Thanks!
Thanks Stomper - sure was a lot of work. Yeah, the hangar rash issue... hopefully once I have things kitted out in that trailer it won't be a problem. Here's one of the reasons I built that trailer - this is a G-62 powered big bird I designed and built that I'm currently finishing up. Definitely need a trailer to haul that thing around!
#370
MN
Big Red
Finally finished...or mostly finished my new trailer. I still need to finish wiring it, etc. Trailer is an Interstate 6x12 (actually 6x14 with the wedge) with an additional foot of height (I'm 6'4"). A little plywood, paint, carpet and an insulated ceiling, dressed it up a little from stock. So far, I love it!
#371
MN
Big Red
Here's the interior. I set the bottom shelf height up to accommodate planes up to 40% or up to a 25-30% plane on floats, which are both projects "in the hopper" at this point. My poor little 30% Carden Cap looks a bit lost in there right now though!!
#373
MN
Big Red
The front is fairly open at this point. There is usually a Mini 3D electric hanging in the wedge to the right of the shelf. I have yet to mount the spare and a few other odds and ends up front as well. It's amazing how fast one of these things fills up! Sure is fun though!
#375
MN
The insulated ceiling helps a lot. I have a cable entry in the floor, and a sky-light/vent in the roof which, when both open, gives a small amount of airfow through the trailer. Most of the time I haven't needed to run with them open. With the exception of a few 90 degree days, heat isn't the problem here in Minne"snow"ta that it is further south. So far no problems. When I arrive at the field and open the doors, the temp is about the same as ambient inside the trailer.
Jim
Jim
