laquer
Old 05-27-2002 | 11:38 AM
Default laquer
i was just wondering has anyone ever used clear laquer to clear coat with? and how does it hold up to fuel thank you
Old 05-27-2002 | 02:35 PM
Default laquer
I've used lacquer in the past for nitro up to 15%. Assuming you're
putting it over paint, you have to use it only over lacquer paint.
If your color coat is enamel then it will wrinkle. Be sure and do a
test first. Otherwise use clear enamel.
Randy
