hinges
Old 02-01-2004 | 12:21 PM
Default hinges
looking for the best way to install hinges on a 25 & 40 size plane do you need to buy a tool to install ???
Old 02-01-2004 | 01:06 PM
barto's Avatar
Default RE: hinges
for pinned hinges: a simple hobby knife will do, greatplanes has a hinge cutting tool but that aint neccesary
for robart-like hinges: i've heard that you dont need a drill, i would use one though
for glue: several possibilities, i always use epoxy
check out the new how to: install robart hinges
http://www.rcuniverse.com/magazine/a...article_id=275
Old 02-01-2004 | 01:07 PM
barto's Avatar
Default RE: hinges
oops, wrong link
http://www.rcuniverse.com/magazine/a...article_id=269
Old 02-01-2004 | 01:08 PM
twostroke's Avatar
Default RE: hinges
What kind of hinges are you going to use? If your going to use CA hinges then you can use just a hobby knife but it is work for plastic pined hinges they make a cheap tool that looks like a thicker bladed and has a v cut in to it to gouge out the wood. If your going to be doing lots of hinge in the future save yourself alot of work and time and invest in a slot cutting tool also get the electric one cause the battery one will only do a few slots befor it needs recharging.....Hope this helps
