Antenna tube
Antenna tube
I am building a hanger 9 40 size piper cub and would like to mount the antenna inside the plane an the instruction talk about using an antenna tube but I can not find one in any catalog I have. Does anyone who or where I can purchase one.
RE: Antenna tube
Use your imagination. Several drinking straws taped together. A piece of paper rolled up and taped. An old piece of nyrod. You can usually buy one at hobby or craft shops.
Tom
Tom
QC, CANADA
RE: Antenna tube
The yellow insert from Sullivan 'Gold n Rods' work as antenna tubes.
Actually,t eh insert for most 'control rods' can work
Most LHS sell some small dia plastic (poly - something) tubes. The work too!
RE: Antenna tube
Like Irish said, Dubro sells one. You can find it [link=http://www.shopatron.com/product/product_id=DUB511/101.0.538.540.0.0.0]here[/link].
Bill
Bill
OH
RE: Antenna tube
Don't bicycle cables have a steel coil under the vinyl?
I have used the plastic sheaths that K&S tubing comes in. It is 1/4" dia and 36" long.
If you use anything that the antenna could remotely possibly fold back on it's self glue a small piece of foam to the very end of the antenna. Then use a ram rod of sorts to push the antenna down the tube. This will also keep it from sliding back out the tube and coiling up in the servo bay.
DEG
DEG
VA
RE: Antenna tube
i used an control rod tube .just rotate the wire when you fish it through the tube.then tie a knot on the end of the wire .then glue the tube where you want it.
