monokote residue >
monokote residue
monokote residue
Old 07-18-2002 | 10:24 AM
My Feedback: (12)
Default monokote residue
I am recovering a set of fully sheeted wings. The insignia blue had to be heated and pulled off when I did this it left a blue residue . What is the best way to remove this residue.
Old 07-18-2002 | 03:27 PM
MinnFlyer's Avatar
About your only hope is sandpaper.
Old 07-18-2002 | 05:18 PM
My Feedback: (12)
Thanks for your input. I' ve found that acetone works very well. You have to do it a little at a time so it does not saturate through the balsa and damage the foam underneath. Then lightly sand it. I finished one wing panel and it came out very well. No imperfections show through the new monokote.
Old 07-18-2002 | 09:15 PM
Try CA Debonder - that has worked well for me to remove monokote adhessive in the past from on top of monokote. Not sure how well that will work on top of balsa ...
R
Old 07-18-2002 | 09:30 PM
My Feedback: (12)
Thank you for the info. I will try it.
Old 07-19-2002 | 02:32 PM
MinnFlyer's Avatar
CA Debonder contains acetone. Just stick with the acetone it's cheaper.
