fiberglass cowl
CT
fiberglass cowl
Hi, I'm rebuilding my 60 sized stinger, and decided to redo the cowl with fiberglass. I made a mold from foam, covered it with 2 layers of 2 oz. fiberglass, then used gasoline to dissolve the foam. Worked well. My problem is that the cowl is not very stiff,and if it flexes too much it begins to crack. How do I stiffen the cowl? Heavier cloth or more layers of 2 oz.
