 How to seal the control surfaces? >
Old 10-03-2004 | 04:26 PM
Default How to seal the control surfaces?
Hello!!!
I'm building a CAmodel Extra 300L 2360mm (31%). It's TOP HINGED.
I've read in some manuals and forums that I should seal the control surface gaps, but I haven't found any info about what is this process exactly.
What I have to do? How I have to do it? What I have to do it with?
Do you have any photos/ draws/ instructions...?
Thank you very much
Juan Sánchez
www.acro3d.com
Old 10-06-2004 | 09:11 PM
Default RE: How to seal the control surfaces?
What that means, simply , is to cover the small gap at the front edge of the control surface to prevent airflow between the control surface and the wing (or tailplane). This helps reduce flutter at high airspeeds. You can come from underneath the surface ( more aesthetic) or go on top with a very carefully cut piece of whatever your plane is covered with and iron it on. Either way, be VERY sure that this strip does not impede control surface travel in either direction.
Old 10-06-2004 | 09:20 PM
mstroh3961's Avatar
Clear ultracote is my prefered method. packing tape works in a pinch.
Old 10-06-2004 | 10:02 PM
I've also found scotch tape works aswell!
Old 10-07-2004 | 08:56 AM
Sealing the gap with your covering material makes for a better finish. I have also used Scotch Crystal Clear tape and works very well, but you have to apply it carefully to avoid small bubbles.
Old 10-08-2004 | 11:47 AM
Make sure surface is fully deflected before applying covering. Had an ultimate that was incorrectly done, would barely roll either way because sealing material was limiting aileron travel and stressing servos.
