will this work? >
will this work?
will this work?
Old 10-01-2002 | 09:01 PM
Default will this work?
hi i damaged the ribs on my chippy at the leading edge if i take some balsa and sandwhich the rib at the leading edge and use a plane to shape the front of the rib will it work adequately? thanks
Old 10-03-2002 | 06:28 AM
That should work fine.
Old 10-05-2002 | 03:12 PM
It might, but you'll need to sand it flat so it doesn't ruin the aerodynamics of the chopper.
