VACUUM FORMING IDEAS
#76
My Feedback: (13)
thats a huge canopy,good news about the plaster did you use a sealer over the plaster I have done reverse molds as a form to make parts and sealed them with oil based polyurathane so I could use wax as a release agent it took several coats before i got a smooth surface and the poly stopped soaking into the plaster obviously vac forming is a different animal I have been watching this thread for years and I am now eager to give it a try
#77
I did not use a sealer and don't on other parts. The PoP has a glass smooth finish and the plastics do not have any adverse effect with the PoP. I even glassed over that PoP mold to make the frame and the PoP is still glass smooth.
#78
I made a mold from Durabond 90 or something like that for drywalling. It was there and looked like something to try. I painted it with three coats of enamel paint that was also lying around. I went to try it with a pop bottle and it just shrivelled up, so I can't say it was successful. I will get the right material some day though. The pop bottle plastic will use a different method. I think the powdered drywall compound will work though.
#79
IL
try looking for ULTRA-CAL 30 a US gypsum product. one source is http://www.reynoldsam.com/p92/USG-Gy...ter/pages.html
#80
My Feedback: (13)
#81
I found the mixing powder type of drywall doesn't shrink, noticeably anyway. Don't know if it is strong enough yet. I hope it works because the original canopy I took it from has been compromised since then. I use it for a first coat on the drywall because of the low shrink and it dries faster of course.
