Spray Adhesive
I use the 3m sprays - sometimes I use 3M77, other times I use the repositionable stuff - forgot what number that is.
Both hold the andpaper really well - the biggest issue is getting the paper off when you want to replace it - which is why I started experimenting with the respoitionable stuff. Works well so far.
Gordon
Gordon
IMHO there is nothing better than the good ol double sided tape for attaching sandpaper to blocks.
I usually leave a "tag" at each end that I can get my thumbnail under to remove when the paper has worn out.
Never had it let go yet...
I use double sided tape too. The 3M 77 spray works well, but that stuff is wickedly dangerous. Do not breath it. Huge cancer causing stuff. I know a lot of people who will not get close to it even if it is not in use. (I have sheeted many a wing with it, probably going to die now).
