New release of software Profili!
I send this message to inform you that a new mayor version of Profili, 2.0, has been released.
Here are some of the news:
- Drawing of leading edge, trailing edge, spars etc
- Drawing of the foam cutting template
- One shot drawing of all the ribs of a trapezoidal o relliptical wing
- advanced filtering of the airfoils by thickness, camber etc
- 500 more airfoils added to the database (more then 2,200 now)
- 20 preprocessed polars for every airfoil in the database (20 different Re from 30,000 to 500,000), more then 500 hours of processing for my PC
- automatic process of the polars for new airfoils or Re
- New function to generate a new airfoil as a mix of two, you can also specify the mixing ratio. So you can generate all the airfoil you will find in a wing with different root and tips ones. Then you can verify the aerodynamic of your wing by generating the polars for the new airfoils...
- Airfoil libraries managing
- import export from-to .DAT file
- and more....
Visit the new web site of Profili by
http://utenti.lycos.it/profili2/
where you can have more info and download your version or order a CDRom.
best regards
Stefano
- and more....
best regards
Stefano
Stefano,
I tried to download the 2.0 version of Profili, but when I clicked on the full version download, I got sent back to the main Profili page. This happened several times. Any idea on why this is happening?
...Steve
...Steve
Originally posted by SHolby
Stefano,
...Steve
Stefano,
...Steve
Uhhm, the Lycos server seems to be down, please try again later....
Sorry Stefano
