balancing props
Hi Does anyone have any tips on the correct what to balance prop? I have two wood props 14x6 13x8 both need to balanced for my Saito 80. I have a prop balancer, one blade appears to be heavier than he other. what is the best and correct way to do the job? thanks
FL
I think you can get away with anything. There is not much chance of getting a prop soaked with fuel, unless you are flying backwards.......
I use lacquer most of the time, it dries very fast. Just use it sparingly, it doesn't take much to balance a prop.
Try painting both tip a bright color (I use white) then put additional paint on the lighter side. This gives a very visible arc and will help you stay clear of the prop. when engine is running. Paint should be fuel proof as with the clear method, urethane would be fine if not water based .
/thanks for all the great tips on prop balance. Now I am up against mounting a saito gk80 on a sig senior arf. Yea I know maybe a Little too much but as they saying goes bigger is better. I like it that way . what I am concerned about is mounting the cowl . when engine is in center position to fit cowl , my center line on the tank is maybe 1/2 " lower than the centerline on the carb.The saito manual recommends that the tank be mounted 5 mm lower than the carb center.,anyone that has tips on this type of installation would be greatly appreciated. thank for all the advice guys.
