Painting Fiberglass?
Could someone recommend how to paint fiberglass. I bought an ARF and the wheel pants and cowl don’t match. I tried using the coverlette spray but all it dose is run.
You probably want to clean the surface to be painted thoroughly, then rough it up with steel wool. Shoot a coat of primer, sand out the primer wit 240 grit , then paint.
Mike
Mike
The surface has to be prepared properly, and cleaned with thinner. Primer is a must, only a light coat. Mist the paint on very lightyl with several coats, waiting until the previous coat is partially dry. I suspect that you are trying to apply the paint to heavy, and too fast.
Vince
Vince
