Balance or Thrust   Cap 231 >
Old 02-06-2003 | 10:09 PM
Default Balance or Thrust Cap 231
Im flying a Cap 231 40 size with a 61 FX, When flying at 1/2 throttle, It needs a no trim on the elev. When I cut the throttle the nose drops, When I apply throttle it climbs! Is this normal for a Cap or does down thrust need to be applied?????????
Any info is appreciated!!!!! Jumper
Old 02-06-2003 | 10:41 PM
I seen on this page here, I think number 6. I need pages like this cuz I cant remember how to fix what. Hope it helps.
http://www.luminet.net/~bkuhl/airplane.htm#trim
Old 02-06-2003 | 11:50 PM
fishgod's Avatar
My Feedback: (13)
Sounds like to much up thrust. You could try putting a washer under both sides of the engine mount on top. Then fly it trim it out and see if it still does it. If not as bad then put another washer behind each side.
Old 02-07-2003 | 01:01 AM
Thanks Michael, That what I was thinking,But I want to be sure.
