Reload this Page >
How to make 4 stroke valve gasket cover?
Old 11-12-2007, 07:15 PM
earl williams
My Feedback: (27)
Default How to make 4 stroke valve gasket cover?
My ys 110 valve cover gasket is shot. Anyone know how to make your own?
Old 11-12-2007, 07:53 PM
fredscz
My Feedback: (47)
Default RE: How to make 4 stroke valve gasket cover?
If not too thick a good gasket can be made out of coffee filter material. I use a piece of glass and smooth out the filter and apply silicone gasket goo to one side just as thin as I can smooth it on. When dry I do the other side.
Fred
Old 11-12-2007, 08:04 PM
Redback
Redback's Avatar
I use gasket material that I get from the local autoparts store.
I press the bottom of the cover on an inkpad (like those used for rubber stamps) then press the cover down on the gasket material. This gives me an outline that I can cut carefully around.
Done this a couple of times now and works OK.
Terry
Old 11-13-2007, 11:35 AM
Edwin
Redback,
That is one of those things that hits you like a phone book in the face! Why didnt I think of that. Great idea.
Edwin
Old 11-19-2007, 07:32 PM
Frasco
Have you tried playing cards, I have usedd them for mufler gaskets and it worked ok.
Old 11-23-2007, 06:25 AM
bigchap
cereal packets work well for gaskets.
Old 11-25-2007, 10:25 PM
Flypaper 2
Gasket maker in a tube.
Old 11-30-2007, 07:54 AM
bla bla
You need leak proof gaskets/material for a YS. Anything else works for a short period, then causes engine problems through pressure loss.
Get a packet sent from Central. Save yourself the trouble.
Any other 4 stroke will run with the valve cover removed. Not a YS. Even a screw loosening on the cover can create typical YS headaches... causing you to be checking pumbing, tanks, glow plugs, filters, one way valves, carbs, needles and ultimately posting for help on the forums when the answer was just an allan key turn away.
Old 11-30-2007, 04:25 PM
loser
My Feedback: (37)
ORIGINAL: bla bla
TRUE....But when A YS is running right theres NOTHING that comes close.....luv em!
Steve
