Home Made CA Kicker
My Feedback: (108)
RE: Home Made CA Kicker
Bottom line, I do not think that there is a home made kicker. Baking soda will make CA go off, however you are then left with a pile of rock hard baking soda to sand off. Thin CA usually does not need any kicker. Kicker is for the thicker CA glues's. Good Luck, Dave
1boxhead (03-20-2023)
MB, CANADA
Commercial CA kickers contain one or more organic compounds known as amines because the CA curing reaction is catalyzed by basic reagents. They usually also are based on a mixture of various solvents.
These substances are not so easy for your average modeler to obtain, since commercial chemical suppliers won't sell to the public.
The best suggestion (apart from time, patience etc.) is very dilute household ammonia in a spray bottle. Organic amines are close relatives to ammonia - and the key here is not what particular base you use but just to make the environment basic.
I have found that in a pinch (i.e. when my bottle of kicker was across the shop and the thick CA I was trying to use to fillet something is starting to flow out of the joint that I am holding with both hands - don't ask[:-]) just spitting on the joint will work - your saliva has a pH on the alkaline side of neutral.
As it was explained to me by my LHS- kicker is only suppose to heat up the CA to cure it instantly. Notably there is smoke and heat associated with kickers. I hate using it cuz it smells so bad and when I can I heat it up with a hair drier. I wasn't born into the world of convenience so waiting 10 minutes doesn't bother me, beats waiting 24 hours like we used to.
ORIGINAL: 2boys
