How do you protect your servo & batt wires, foam, cable clamps or what????
WI
Some of you out there must have some good ways of protecting wires during flight to prevent the insulation from rubbing aganist the wood and possibly causing the insulation to wear through or the wire to break. Would you care to share some of your ideas?
Birman
Birman
GA
RE: How do you protect your servo & batt wires, foam, cable clamps or what????
I sometime use fuel tubing sliced open and wrapped around the wiring where it passes through or is in contact with framing. Also, tubing can be mounted on the framing.
