Reload this Page >
servo lead clips
servo lead clips
Old 10-19-2008, 04:45 PM
mmiller1
My Feedback: (75)
Default servo lead clips
I have seen several fasteners to keeps servos from pulling apart. The 'black boxes' with a snap lid are prone to opening, especially with a vibrating gas engine. I did see some other kinds (simple in design, green in color) and can not find any luck by googling a description. Any leads out there?
Tim
Old 10-19-2008, 04:49 PM
FLPilot
My Feedback: (23)
FLPilot's Avatar
Default RE: servo lead clips
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDT86
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXE971
Both of these work well. One twisted wire, the other flat wire.
Old 10-19-2008, 05:14 PM
Villa
Villa's Avatar
I use and like the yellow clips FLPilot mentioned, but only on the ailerons on a plane with a wing that must be removed for transport. On all of my other servos I use dental floss to tie the servo plugs and sockets together. Works for me.
Old 10-19-2008, 08:19 PM
dignlivn
FWIW,
I use the black boxes, and they work.
Bob
Old 10-19-2008, 09:12 PM
AirWizard
AirWizard's Avatar
I use the yellow ones!!1
Old 10-20-2008, 12:08 AM
The Ghost
The Ghost's Avatar
I use cotton thread, get several hundred joints out of a bobbin and in a smash it will break with out damaging the leads.
Cheers
Old 10-20-2008, 10:00 PM
nitrohog
I use small zipties, but you guys have me thinking about using lacing cord.
Old 10-20-2008, 11:45 PM
42etus
42etus's Avatar
Three words: Heat Shrink Tubing
Paul
Old 10-21-2008, 07:19 AM
Edwin
I use kite string.
Edwin
Old 10-21-2008, 03:07 PM
anuthabubba
My Feedback: (102)
A wrap of 3M 'electrical' tape has worked for me for years.
Terry in LP
Old 10-21-2008, 04:00 PM
Edwin
Terry, Do you have any issues with the connectors being sticky when unwrapped? I did that for awhile but it left the connectors sticky. The shrink wrap works good but is a little costly. I only went to string because I was out of shrink wrap, it worked ok so I stuck with it.
Edwin
Old 10-22-2008, 11:22 AM
JustErik
I use whatever I have laying around....have used dental floss, masking tape, Blenderm, electrical tape, spider wire monofilament, etc. Poke around a bit and you'll probably come up with lots of possibilities.
Old 10-22-2008, 12:09 PM
carrellh
carrellh's Avatar
I just use dental floss or thread. Cheap, simple, effective, easy to remove.
Old 10-22-2008, 02:32 PM
flynte
I use this plastic clips. Work great for me. ebay item # 280273460314
flynte
Old 10-22-2008, 02:36 PM
OldScaleGuy
OldScaleGuy's Avatar
Dental floss for me too. Use it for its main intent as well.
Old 10-24-2008, 07:57 AM
Jezmo
Jezmo's Avatar
ORIGINAL: OldScaleGuy
OldScale, that's some good lookin teeth in that smiley face. LOL
Like one poster said above, I use whatever is lying around including zip ties, lacing cord, dental floss, adhesive tape of various types, the little black boxes, the little yellow servo lead clips, and yes the black electrical tape makes them sticky but it isn't hard to clean off.
Old 10-25-2008, 03:00 AM
beepee
Dental floss. Besides, my connectors have not had a single cavity since I started using it.
Bedford
Old 10-25-2008, 08:37 PM
MinnFlyer
MinnFlyer's Avatar
I don't use anything and I've never had a servo come unplugged
Old 10-31-2008, 06:40 AM
Jezmo
Jezmo's Avatar
ORIGINAL: MinnFlyer
I am sometimes a bit of a klutz and have pulled an extension off inside the wing and had to re-snake it back through. I don't use anything where the connectors are easy to get to and I've never had one come apart in the air either; only from my clumsy self accidentally snagging it on the ground and pulling one apart. I guess the point here is I haven't seen them come apart either (been flying RC for 37 yrs) without some human intervention whether intentional or unintentional.
Old 11-01-2008, 07:08 AM
dhal22
i've had a throttle servo come unplugged (loosened rather) from the receiver, didn't know what had happened. finally figured it out and used a rubber band around the entire receiver and plugs. seems to work fine. similar to other ideas here, dental floss, etc. it doesn't take much.
david
