CA glue stain removal
My Feedback: (71)
Anyone know a good solvent that can take off the whitish stain from CA glue on monokote and canopy surface? I used the CA Debonder but it caused canopy surface to feel rough afterward. I think Debonder does eat a bit into the canopy material.
My Feedback: (9)
LA
RE: CA glue stain removal
I think that Naptha will remove the fogging and it won't hurt the canopy. I have been told that Future floor polish will also remove it but I havn't tried that yet.
Ben
Ben
OR
Acetone will remove it from the Monocote with out buggering up the covering. Don't rub too hard, just use a soft cloth with some acetone on it and rub gently. Let the solvent do the work. I can't be sure it would be safe to use on the canopy though.
Pure Nitro Methane will soften CA. Try it on a piece of canopy material. I used it to get some CA off a Composite ARF fuse. I did not hurt the finish.
Regards
Regards
CO
Not sure what it's made of but Super Solvent is the best I've found for cleaning up CA spills and runs.[link=http://www.constantines.com/index.asp?PageAction=VIEWPROD&ProdID=36]Super Solvent link[/link]
