Did a dumb thing today
PA
I've been flying for quite a few years and I've never done this before.
I did my pre-flight, started up and taxied to the end of the runway and did my range check. Everything is go.
I took off and about 1 minute into the flight the plane rolled 90 degrees to the left and restraightened itself immediately. Hmmmm. Probably dumb thumb. Flew for about another minute and the plane did the same thing. Hmmmm- better get her on the ground. On approach, the plane did it again. Fortunately I was able to get her on the ground without any damage.
I taxied back to the line and when I shut the engine down, I noticed that I had never extended the TX antenna.
I guess it all comes down to complacency. I think I will write down all the things I need to do and keep it in my flight box. I can read it prior to take off as a double check.
Its hard to get old.
RE: Did a dumb thing today
I have never done it but heard about it and I'd say your darn lucky to still have a plane. A lot of times they fly off into the sunset. I think it is one of the more common mistakes made. I try to do the exact same things, like a pre-game ritual. Extending the antenna is done every time just as I begin to start my taxi to the runway. I've done it that way so long that now it is like driving without a seatbelt. I feel kind of weird when I don't do it.
Pretty soon all the TXs won't have those extendable antennas anymore.
When I was learning.......I guess I should say beginning to learn because I seem to learn everytime I go to the field.........one of my instructors always flew with a 2.4 radio. My trainer that we used was 72 mhz. So here we are, flying around the pattern when out on the downwind, my plane drops about 10 or 15 feet like it had hit turbulance or something. He asked me if I did that to which I replied no. We both assumed there was some air current that caused it and kept flying. Next pass around the pattern and it did it again, in the exact same place, to which we both said bring er down and let's check this out. Lined up on final and all of a sudden my instructor gasps and pulls the antenna out. Plane flew great afterwards!
When I bought my 2nd plane, I also upgraded to 2.4 and now everytime I get the trainer out for a nice relaxing cruise, I have to double check myself just to be sure I did indeed pull that antenna out. Been fortunate so far and haven't forgotten that antenna when I fly the trainer, but Murphy is always lurking..........
My Feedback: (22)
IN
Been there done that! I really felt stupid when I had only solo'd about 2 weeks before. My instructor walks by while I'm flying and said, "I didn't know you fly spektrum radios" I replied "what are talking about" He just pointed to my antenna and frowned. Lucky for me no loss of signal or glitches and I immediately pulled the antenna out.
Now I have switched to Spektrum and don't have to think about pulling the antenna up. If I have the wrong airplane on the radio, the Rx will not respond, which is another nice feature.
I have T/O with it down and had to hoist it up while flying, so now I have it up after I turn on the radio. Saw a guy kill a brand new pattern plane by not putting the antenna up; second flight. Total loss. His job, airline capt., so it can happen to anyone.
GA
Been there and done that as well but the results were a lawn darted NexStar trainer. It got out of range as I had it in a 30 degree right bank at full throttle. It was a fairly spectacular crash to watch as it went in at about a 75 degree angle full throttle. Boom! All I got out of it in working condition was the servos, a couple of control rods, the RX battery and landing gear.
I had been flying with Spektrums for a couple of years prior and pulled out the NexStar with Futaba 72 Mhz. to get it in shape for my daughter to begin training with it. Now the trainer is an Alpha 40 with Spektrum...$300.00 later.
My Feedback: (102)
LA
I do the range check seperately before getting on the runway and never even taxi with the antenna down. If there WAS a problem the plane might run/fly away.
Terry in LP
Terry in LP
MB, CANADA
After i start the plane in the starting sticks (or whatever they are called) I do a run up, controll check and before i remove the plane from the stand, I extend the antenna. I almost forgot the antena once (it was pointed out to me) and boy did i feel dumb. Since then, I have always remembered. At least you plane is unharmed and you have learned from the mistake.
MI
ORIGINAL: daveopam
This is going to be more common I am afraid in the next few years. I fly some on 72 and some on 2.4. I have not flown with the 72 down, but I have tried to pull up on a 2.4.
david
david
I have a good TX in 2.4 and want to use it as much as possable , plus I know I will forget the ant. or forget the freq. pin.
Problem solved.
sticks
I have forgotten to pull out the antenna a few times too (I've also forgotten to unroll the Rx antenna a few times )
With the 2.4 systems, I can't tell you how many times I've been flying along and suddenly think, "Oh Crap! My antenna isn't out!"
ORIGINAL: Steve Collins
My method is that I NEVER, ever, start the plane without the antenna extended. The antenna gets extended before the transmitter switch is turned on.
ORIGINAL: MinnFlyer
The problem there is that I've seen too many antennas get eaten by props! [img][/img]
PA
One of the reasons I shared this was to point out how easy it is to become complacent.
There are so many times while flying, driving, or at work we do things by habit rather than thinking about what is going on.
I saw a friend put his hand into a prop reaching for the heater. This person has been flying for many years. He knows better but just wasn't thinking.
The crash of Eastern Flight 401 in 1972 happened because the cockpit crew became involved in solving a landing gear light problem and forgot that no one was flying the plane!
Little things add up to big problems. Please guys- think about what you are doing all the time.
MB, CANADA
I've done the same thing and was lucky and got by with it. My plane never gave any indication of signal loss, luckily I noticed the andtena wasn't extended and got it up before disaster struck. JR must make a good radio gear because the plane was out probablyover 200 yards and was on the way back when I noticed the antenna down. The friend I was flying with commented that it was quite a range check!
bhady
bhady
MI
ORIGINAL: andrew66
Correct me if im wrong, but other than the possibly of getting the antenna in the prop, I was told that having the antenna extended when in close proximity to the model, it was bad for the radio system. I was shown from day one of rc that it was good practice, and easier on the radio system if the antenna was only pulled out one section. (apparently having the antenna all the way down is bad too)
My own mindlessness showed up earlier this season while I was making some aileron adjustments to the plane. As I was cleaning up at the end of the evening, I removed the wing and began to wipe it down. When I bumped the Ailerom linkage, It fell off the servo. I had neglected to put the screw back in the output shaft. That could have been ugly.
MI
ORIGINAL: JRFisher
Crossman- not near as bad as if it would have been the elevator!
When I first started flying 3 years ago , my trainer had been in the basment for about 12 years. One evening we had a lot of wind and rain and were under a shelter at the field. The wind blew my plane into a table and knocked the tail off. In the process of repairing it, I found out that while the plane was in the basement, the mice had chewed the elevator pushed nearly through.
ORIGINAL: daveopam
david
david
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
Having and staying with a routine is critical. We can all go on with dumb things we have done. Those are often the things we now check several times before every flight. The full-size boys have checklists printed right in the cockpit.
We had a saying painted on the hangar:
AVIATION, LIKE THE SEA, IS NOT INHERENTLY DANGEROUS. HOWEVER, IT IS TERRIBLY UNFORGIVING OF ANY CARELESSNESS, INCAPACITY, OR NEGLECT.
This goes for us model pilots as well. I could tell you how I know . . . .
My Feedback: (16)
CA
Hey buddy,,, glad you got her down in one piece....... Dumb????????????? yes. But now you have learned something............ do it twice and they call it stupid......... there is a differance you know.
Good luck and be happy you got her down in one piece.
