Lustrecote Removal >
Lustrecote Removal
Lustrecote Removal
Old 03-29-2002 | 02:57 PM
Default Lustrecote Removal
I got a little overspray when I masked off my cowling because my Great Planes masking tape came unstuck when it got wet with paint. I am using Lustrecote spray. It is a very small amount but in several places and it is black smudges over white. Paint thinner won't touch it. Anybody tell me what you use as a solvent? Or do I have to respray the white area.
Old 03-29-2002 | 04:23 PM
Use a q-tip and some a bug and tar remover. It will be strong enough to remove the paint from the clear but not the clear.
Old 03-29-2002 | 10:35 PM
I used a q-tip and scrubbed with bug and tar remover--didn't even phase it? Anybody got any other good ideas?
Old 03-30-2002 | 06:51 AM
You could use acetone. Get it at any hardware store. But be warned. It will attack most paint or plastic. Use very little on a q tip. And you may have to spray a new clear coat on your cowl.
Cheers
Old 03-31-2002 | 04:53 AM
My Feedback: (9)
Default Overspray
Try a product called "Oops!". You can get it at Wally World or Lowes. Usually in the paint dept. Works VERY well and even smells good. It's very gentle on plastics too.
