what paint???
what paint???
I have to paint the cowl of a cub in the military scheme. Lustre coat isn't made in olive drab. What over the counter paint is nitro proof? is it Rust-oloeum or just a laqure (sp) base paint that I am looking for ?
RE: what paint???
Nitroproof. Klasskote Epoxy paint. Check out Klasskote. www.klasskote.com. If you know the FS number for the paint, they might be able to mix up a custom colour for you.
Jim
Jim
RI
RE: what paint???
I just finished my GP P-47 in military drab colors. I usred Rust-oloeum Camofloge colors, After i let that dry for a few days, I used Lustercote clear over it. The first coat of clear I used very little paint to make sure it didn't bubble it. And let the first coat DRY good. then put more coats on. Worked great.good luck
RE: what paint???
thanks for the reply(s). I've been on the Klass Coat site and have ordered a small sample of the Olive Drab as a trial. Years back I did a Smith Mini Plane with epoxy and it came out pretty good. I think I will be pleased in the long run if I stick with what I know will work even if it is a little on the pricey side.
