Balsarite thinner
TX
I recently had the same issue, so I decided to use what was in my shop and see which worked best. I tried MEK, acetone, laquer thinner, mineral spirits and xylene. The MEK worked best, but I had to let it sit in a sealed glass jar for a few hours. I had no luck with the other solvents. I've read that nitrate dope thinner is the same as Ironex, but I've never tried it. Use face and lung protection. Nasty stuff!!
Paul
Paul
MS
ORIGINAL: vertical grimmace
Balsarite is great stuff. I am using a full scale fabric on a very large model and the fabric nees to be adhered somehow. I am going to use Balsarite as opposed to doping the whole aircraft. It will not smell as bad! Try it, you will like it.
Sort of like "the real thing", if you know what I mean.
