87" EF yak
TN
anyone have any tips for installing the mtw td 75 k cannister on a EF 87 " yak, I had a over heating issue and would like some input how top properly do this
GA
shouldn't need anything special.. we use the K&S softmounts from DA, but just about any mount would work fine.
You can check out the manual for the 88" Yak here
http://www.extremeflightrc.com/manua...ManualRev2.pdf
about page 35 or 36 there are some pictures of a pipe install that should help.
The plane uses a 25mm drop header
