 U-Can-Do mod posting - drop fuel tank >
Old 08-15-2010 | 11:40 AM
Default U-Can-Do mod posting - drop fuel tank
I thought I would post my mod pics. The last UCanDo I had siphoned like crazy with the tank so much higher than the carb. This is a little more like it.
I found that from time to time, I would have to start the plane inverted anyways - I think that was simply because the engine was inverted and the glow plug didn't like that. At least I didn't have the fuel siphoning though. Usually my first start of the day would go just fine, but subsequent flights required inverting to start.
AIRCRAFT: U-Can-Do .46
ENGINE: Magnum XL70 4 stroke
ID:	1484256   Click image for larger version
ID:	1484257   Click image for larger version
ID:	1484258   Click image for larger version
Old 08-15-2010 | 11:42 AM
Default RE: U-Can-Do mod posting - drop fuel tank
I forgot to mention... make sure you allow a little more airflow exit in the cowling, as the exit airflow in the air frame has been reduced somewhat.
