RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   First bipe (https://www.rcuniverse.com/forum/tips-techniques-180/11315765-first-bipe.html)
Chris Nicastro 12-03-2012 10:10 PM
RE: First bipe
I fly a GP Super Stearman with an OS 160 and an H9 Fokker D7, modified, with an OS 95. I have owned an H9 Camel as well, OS 65LA. I have a buddy who is a scale WW1 builder who has me pilot his creations as well. Ive flown his SE 5, Spad and coming up is an Albatross and a Neuport 28.
What you have to understand with all of these planes is that no two fly alike and you have to respect each type. Thats what would give them different advantages in combat.
Whats common among the scale bipes is they have narrow gear, high CG's, and a short nose and/or short tail.
Of all of these bipes Ive flown I would suggest the SE5 for a beginner. It has wing dihedral and a longer nose with a good amount of tail surface area. It responds well on the ground and in the air.
When taking off with these bipes the basic procedure I use is to hold up elevator during taxi, fade that off back to neutral as I add power. Use rudder as needed to go straight. Once the tail is flying begin to pull back as the plane speeds up.
Landing is the part where you need to really understand your planes characteristics. As all of the guys have said you must be on power when approaching the runway but what nobody has elaborated on is why beyond the obvious high drag character of bipes and especially classic bipes. The reason is that bipes will flip over if you cut the power abruptly especially on grass. The drag of the wheels will allow the high CG of the plane to take over and flip the plane on its back. You should touch down and roll out on power and then bring back the power to taxi power, or slightly higher, gradually waiting for the wings to stall out and the tail to settle. Once the tail is on the ground you should have a slight bit of power on to keep air on your tail surfaces. Cutting the power to idle will also take away your positive control. On a paved runway a bipe should not flip over, they can but not generally, but they will veer off line out of control if you cut power too soon. Again the high CG and landing gear design coupled with a short tail, worse if there is a tail skid, all contribute to loss of control if you dont learn to handle the plane correctly.
This is how I approach bipes with or without tail wheels, high or low performance.
The GP Super Stearman has great overall performance and I fly the heck out of this plane, no mods, as is. Its my favorite all around biplane, its scale-ish, its big enough, and it looks great in the air. Landings are a challenge because it requires a very specific routine to pull off a good looking scale landing. I call it doing it by the numbers but its a lot of fun. Do it wrong and it will bounce, do it right and its very slick.
Thats my $0.02, I got sucked into bipes after flying one, you will too if you give them a chance.
airega1 12-04-2012 06:35 AM
RE: First bipe
I hate to trump all you guys but I was fortunate enough to aquire Steve Strickers original TOC Ultimate 8 years ago, this is one phenomenol flying aircraft. I removed the original 4.2 glo conversion and bolted my Brison 6.4 on the nose and never looked back. In all my years of flying I've never witnessed a plane with such crisp and straight characteristics, uplines, downlines, Knifedge, all effortless, I just love this airplane and it was built in 1990 and he flew it until 1995 always placing in the top 5, he beat everyone with the exception of Chip Hyde, he finally beat chip in 1996 with an Extra 300.
A bit more about the ultimate, it has a 79"WS and the fuse is 92", tracks straight as an arrow even on the ground, it is considered 37% and was built up in MD. utilizing a GL Hobbies Ultimate. The wings are balsa sheeted foam (one piece) maybe 1" thick, the aileron servos stick through, fiberglass fuse with foam formers laminated with paper, all up weight is about 24 lbs. There was a backup Ultimate with plug-in wings he never flew in competion and was destroyed on takeoff after he sold it.
vertical grimmace 12-04-2012 08:36 AM
RE: First bipe
The Ultimate is an example of a bipe that handles almost nothing like any other bipe! The thin wings and clean lines allow for landings that act more like a monoplane.
As far as the aircraft at hand, the BUSA pup, you should not have any surprises. They fly great. One thing though, the rigging that BUSA recommends sometimes lends itself to an aircraft that climbs, so be ready for this on takeoff. This is a symptom of positive incidence angle relative to the stab. This is the case at least with the triplane and the Fokker DVII. Have fun and good luck!
fly20 12-04-2012 09:03 AM
RE: First bipe
Well knowing that flying season is coming to an end here soon, I went to the field this morning, despite the misty, cold conditions and had 2 nice flights. Like you said it did take a bunch of down clicks and I it did bounce it a few timesthe first landing, but all in all I'll take it. Now I can add the extras to itover the winter. Thanks to everyone for taking the time to post theirexpert advice. It was much appreciated.
flycatch 12-04-2012 10:35 AM
RE: First bipe
Your PUP is no different than any other tail dragger but it has one additional wing. Tail moment is the key to the way the plane behaves in the air or on the ground. The longer the tail moment the more longitudinal stability. Your PUP is designed to be agile in all three axis and lacks a long tail moment arm. With this said your major problem will be in takeoff and that is where your skills come into play. You will be using; rudder, throttle and elevator control to track and control airspeed prior to rotation. My first biplane was a GP Steerman which had a long tail moment and presented few problems. My next and last bipe was a BH Pitts S1S and this is what is called short coupled. The Pitts was what you would call squirrelly on take-off until you mastered the three control inputs I mentioned previously. Most is not all biplanes can be landed three point however the Pitts most be landed on the mains. Your PUP should be flow off a grass field and this will help during takeoff. Others have mentioned maintaining the proper airspeed during landing and again this is something that is learned through trial and error. Find some information on the full scale model and its' flight characteristics and this may also help.
