RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Starting screws and nuts in tight places (https://www.rcuniverse.com/forum/tips-techniques-180/11608082-starting-screws-nuts-tight-places.html)
JUSTMECAT 12-16-2014 06:32 PM
Just thought I'd share a little trick to help installing nuts and bolts in those tiny little spaces we all love so much. I use a section of silicone or rubber tubing. Insert your screw or nut into it and you will be amazed at the places you can easily start the threads in now. Added years to my life, I'm sure. LOL. Please post anything you have to make assembly less of a challenge. Thank you to all. And to all "Happy Holidays!"
52larry52 12-16-2014 09:31 PM
On nylon 1/4-20 wing hold down bolts, I taper the first 3 or 4 threads using a cheap kids pencil sharpener. The hand held pencil sharpener has a small razor blade inside it (don't tell the school board people or they will ban them) and cuts a nice clean taper on the end of the nylon bolts, making them easy to start. On metal wing bolts, I also taper the starter threads on a bench grinder, and of course that requires cleaning the threads after grinding the ends. This makes airplane assembly at the field less of a hassle.
Villa 12-23-2014 08:30 AM
A trick that I use is to always make a small hole for the screw. Sometimes I make a spade drill from a thin piece of piano wire by hammering flat one end and with a file turn that end into a point so that it will cut into soft material. It is now a SPADE DRILL. I chuck the wire in my electric hand drill and will bend the wire as needed to go around obstructions.
grosbeak 12-23-2014 11:13 AM
Great thread!
I made a removable gas tank tray for my current build that is secured to three beams with six socket head cap screws, each with a lock washer and a flat washer.
https://farm8.staticflickr.com/7507/...1d672472_z.jpg
https://farm8.staticflickr.com/7547/...0a9fe378_z.jpg
It was easy enough to remove the tray after gluing the beams in place, but reinstalling the tray once the tank was strapped in was a little more difficult. I tried tweezers and pliers but what worked best for me was a small magnetic pickup tool. Held the washers on too.
https://farm8.staticflickr.com/7541/...07e837a8_z.jpg
Using the tool it's easy to put the bolt in the hole.
https://farm8.staticflickr.com/7469/...cfa7878d_z.jpg
Sliding the tool sideways off the head of the bolt leaves the bolt and washers in place for the ball driver.
52larry52 12-23-2014 08:59 PM
grosbeak, Why not magnetize your ball driver?
BarracudaHockey 12-24-2014 06:10 AM
If you put a nut on before you grind the tip, when you remove the nut it will chase the threads. Same thing I do when using a Dremel cutoff wheel to shorten bolts.
52larry52 12-24-2014 10:57 PM
BarracudaHockey, You didn't have to say it twice :) you were right the first time. "Cuda man" is right, putting a nut up on the threads before you taper the ends is a good way to clean the now roughed up threads. Maybe a little touch with a fine file afterwards and you are good to go.
BarracudaHockey 12-25-2014 05:44 AM
I i only posted that once, RCU was acting up LOL
52larry52 12-25-2014 08:45 PM
So, that's your story and your sticking to it, huh? It was RCU's fault! OK, just having fun with the situation, your information was good. Merry Christmas :cool:
EHFAI 12-26-2014 05:17 AM
Sometimes affixing the nut to one's finger with an adhesive putty, Elmer's Tac N Stik is one of several brands, provides a means of getting the nut where it's needed while also giving a bit of "feel" for starting the threads as the screw is turned.
kenh3497 12-26-2014 03:56 PM
A piece of masking tape will hold a nut in a socket or nut driver nicely. The same tape made into a loop, sticky side out, will hold a nut on your finger.
Ken
JUSTMECAT 12-26-2014 07:06 PM
Unfortunately the tape remains with the nut. Not so "pretty." Thank you all for posting. Keep them coming. Something simple to you may be the final straw for another. I've given up several good ideas only to be floored by an easier way after I scrapped it.Wasted alot of time and money due to a lack of knowledgeable fellow enthusiasts. I am at a point where most of what I do is second nature now and it's hard to remember the early tribulations. But, I am a fabricator/ welder with 20+ years paint experience. If I can help with anything? Please ask. I got into this hobby to have fun. Only to find stiff lipped competition. No fun in that. Trophies and titles are a loss when compared to winnings reaped from helping someone else reach a higher level.PEACE!
kenh3497 12-27-2014 10:18 PM
Put the sticky side of the tape in the socket or nut driver. The loop of inside out tape is around you finger. "Rarely" have I had a piece of tape stay on the nut. If it does, it's usually in a place where it can be seen so no consequence.
+1 on sharing info to help a fellow modeler.
Ken
JUSTMECAT 12-29-2014 05:45 PM
I had it backwards. Sorry. I taped the washers over the nuts in the driver. Since the tubing epiphany I just use my sons glue stick on the end of the tubing. holds the washer in place after I insert the nut into the tubing. No more pretty blue tape inside my hulls. You may not be able to see it. But, I know it is there. Eats at my soul.
grosbeak 12-30-2014 08:19 AM
Not a bad idea! I'm just not sure it woud have enough power to hold both washers up as well.
JUSTMECAT 12-30-2014 02:57 PM
I pretty much just build boats anymore. Haven't turned sticks into planes in a long time. Being boats, the socket heads are on the exterior. And the nuts and washers are inside. Small hardware and really small tight spaces or insane angles that won't afford the use of a ball driver or socket. I also have cannibalized a couple of my kids "magnetix" toys for the rare earth magnets inside them. They are 6mm and fit perfectly inside the tubing. They have several ounces of pull and will hold more hardware than you need to hang. Unfortunately they are attracted to everything ferrous in their proximity. Another thing I have done for years is to use cheap hollow core doors for layout tables for my wood kits. Perfectly flat. Push pins are easy to insert and hold. Can be cut to necessary size and store vertically with ease. Cheaper than a workbench and great for apartment dwellers. Keep rattling my brain. I'll keep recalling tidbits to share. Thanks for the input.
TecBrat 11-09-2017 11:12 AM
Thank You!
I'm not even an RC owner.
I was struggling with this issue on a full sized Cadillac and your tubing suggestion was so amazing that I decided to sign up to this forum just to tell you how much I appreciate this amazing idea!
Thank You!
