Mono show through problems
Hello
I have seen and had ugly show troughs with supposedly opaque Monokote I.E. where balsa was filled, or had dark grain etc. So my question is what can you put on to provide a uniform base that the Monokote will stick to ? Far to late I learned that dope is translucent as well and one should always put a base white or silver base coat under the colored topcoat so can one say spray the wood with silver aluminium paint ? it very high hiding and generally heat resistant but I fear monokote will not stick to it ? Jay |
I have successfully used Top Flite Lustre Kote "white Primer # TOPR 7527" for that exact purpose. Last winter I had occasion to rebuild the wing on my small J-3 Cub float plane (must be hard water around here :)), and I had some dark mismatched material areas that were going to show through the Cub yellow covering. I misted several coats of the Top Flite white primer on the problem areas (not the whole wing) and after covering they were 100% invisible even through yellow covering. I had no problem with the covering, Ultra Cote in this case, sticking in the painted areas.
Thanks Larry
I am using the lighter and most likely even more translucent yellow and white primer seems an excellent material for this as it's high hiding as painters say due to having lots of solids in it I wonder which is heavier white or the silver al paint I was thinking of ? |
| All times are GMT -8. The time now is 03:33 AM. |
