Installing Robart Cub gear
I picked up a set of these for my 1/5 Sig Cub and really have no idea what is the best way to install them.:confused:
Need some help before I make a mess of it. Thanks |
Well, you bolt them on just like any gear,,, You may need to add hard points on the right spots on your plane,,
not really sure what you're unsure about |
Robart's site has this sketch, which may help. These are somewhat complex (at least if they're the same as the quarter-scale set).
http://cdn.shopify.com/s/files/1/033...s/689.pdf?4066 |
3 Attachment(s)
Here's a couple of pictures that may help. The mounted gear on this 1/5 scale Sig Cub is a Wallace scale gear, the Robart mounts the same way. I recommend putting a couple of basswood crossmembers inside the fuselage to screw the gear into, it will hold much better than balsa. The picture showing me holding a second set of gear struts is the Wallace gear mounted, and I am holding the Robart gear.http://www.rcuniverse.com/forum/atta...mentid=2201660http://www.rcuniverse.com/forum/atta...mentid=2201661http://www.rcuniverse.com/forum/atta...mentid=2201662
| All times are GMT -8. The time now is 07:53 PM. |
