RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Inexpensive Airplane Stands (https://www.rcuniverse.com/forum/tips-techniques-180/1496758-inexpensive-airplane-stands.html)
2mistakeshigh 02-04-2004 03:12 PM
Does anyone know of an inexpensive airplane stand that can be used at the field or at home for repairs.
amelia-air 02-04-2004 03:21 PM
RE: Inexpensive Airplane Stands
ORIGINAL: 2mistakeshigh
I use the one from Dubro --works great --Two pieces of foam ,& two plastic tubes..I think they are about $10.00
tommy s 02-04-2004 04:01 PM
For a quickie you can cut "U" shapes in the ends of a styrofoam beer cooler.
A couple of bucks and lasts a long time if you're just a little careful with it.
tommy s
"TEXAS ENGINEERING"
Arebeck 02-04-2004 09:30 PM
I just use a cardboard box of a suitable size for a quick, easy, cheap and durable stand. Use a knife to make cutouts suitable for your plane and your good to go.
BCJETJOCK 02-04-2004 11:17 PM
1 Attachment(s)
Not sure if this is what your looking for, but is made out of 3/4" pvc. If you don't glue it completly together, it takes down pretty easily. To use at home and at the field. I have 2. One for the house, and one for the paint booth.
rajul 02-05-2004 06:26 AM
What size plane are you talking about ?
2mistakeshigh 02-05-2004 08:42 AM
The plane is a SIG Spacewalker II 40 Size. 63" wing span and should weigh approx 6lbs when finnished.
rajul 02-05-2004 08:50 AM
The Ernst Ultra Stand is simple and very durable. It also has compartments for tools. Very handy. I am using this stand
http://www2.towerhobbies.com/cgi-bin...?&I=LXE974&P=7
rsallen13 02-06-2004 12:15 PM
I do the 3/4" PVC thing like BCJETJOCK. Under ten dollars, all the parts are at (insert favorite hardware store) stays together without glue. Can use self tapping screws if needed to hold sections together. Fully customizable and upgradeable.
Jim Finn 02-06-2004 07:32 PM
1 Attachment(s)
Here is the way I store and transport my planes. Racks come apart at the field and I have a short stand for each plane. (3/4" PVC.)
TLH101 02-06-2004 07:58 PM
1 Attachment(s)
I use stands like JimFinn is using. I have several in different sizes. The one in this pic is screwed to the old tv stand so it will roll around the shop. It is also set-up for some PVC legs that will plug in if needed. Just some PVC pipe, crosses, & tee's.
Jimmbbo 02-24-2004 12:08 AM
1 Attachment(s)
Robart makes a styrofoam stand - $15 - the 45 degree paddes supports are very solid and allow work on the fuselage at any angle...
http://www2.towerhobbies.com/cgi-bin...?&I=LXES03&P=7
Liked the idea so much, I "adapted" the idea and added it to my field box -:D God bless PVC!!
Cheers!
Jim
