Paint primer
What brand or type of inexpensive primers are being used that can be sanded?
Paint primer
I have used the Krylon sandedable primer in a rattle can, but I have had lot better luck with auto primer in the gallon can for less then $30.00. It dries faster, sands better, is just btter in all aspects. The only problem I have had is you need good spray guns to do a good job.
Dru. |
Paint primer
Dru: Did you find that it took a few days to dry before the Krylon Sanding Primer would sand. I have some, but it does not seem to powder. I have been told it takes four days to dry. I have not given it that much time on my sample.
Ed |
Paint primer
The best rattle can primer is certainly Duplicolor, kind of expensive but the easiest to use, dries fast and can be sanded right away. I have been using Evercoat acrylic primer less than $25.00 a gallon and works fantastic but you need a spray gun. Harbor Freight tools has a HVLP spray gun for $12.00 that uses a shop vac for air surprisingly the thing works great, I have about 6 spray guns and I grab that one when I shoot primer or PVA.
Here's the link http://www.harborfreight.com/cpi/cta...emnumber=47482 |
Paint primer
The best primer for a hard surface..........haven't used it on fabric.........is "Dupont" "waterborne" #210 S You can brush it or spray it. Even with an air brush. Auto paint stores are the only place to find it & I think it only comes in grey. Very easy to sand and lots of pigment.
Riley |
Paint primer
The post did say "inexpensive" primer. If we are talking auto primer, then nothing period compares to PPG K36 for sandability and fill.
Vince |
| All times are GMT -8. The time now is 05:30 PM. |
