Chipmunk rudder pull pull
Hi
I want to convert my CG Super Chipmunk Rudder to pull pull - I am not sure if I should run the wires straight to the tail wheel torque rod or route them through cables to the rudder. Any suggestions ?? Tim South Africa |
Cables to the rudder.
I use the dubro system and use some yellow inner Sullivan inner nyrod for exits on the pull -pull systems that way I don't worry about lining up the cable from the servo to the rudder. System has worked for me with no problems. |
My post should have been clearer - it is the lining up of the cables that is a problem. Does the inner nyrod wear ? Tim |
I have a Fun Aero 1/5 scale SE5A all the pull=pull cables 2 on rudder and 4 on elevator were done using the inner nyrod method. Been flying the airplane for 2 yrs there has been no sign of wear to date. Same goes for my 1/4 scale Champ.
Thanks r1morris
I will go this route - a straight route to the rudder is very difficult on the chipmunk. Tim |
When you install the inner yellow nyrod use some length like 4 to 6 inches inside the fuse I found that it's easier to run the cable and does not create any friction that I can detect. it also makes it easy to work on the pull -pull system when needed.
Another Q: Are you using metal cable or Kevlar?
I have used nylon coated metal cable with nyrod inner
to route it around the bend. Tim |
I use whatever Dubro uses in their Pull-pull system and have never had a problem. Pull -pull systems and not strung bow tight so it's not like installing a saw blade. I little positive tension goes a long way.
| All times are GMT -8. The time now is 02:05 AM. |
