Covering a balsa cowl
OK, so you've spent many an hour giving your new 4* etc a nice nose job by carving and sanding a nice round balsa cowl
Example instructions Now, how do you cover this cowl in Monokote or Ultracote without spoiling all that work? |
I covered mine W 4pcs of monocote rite with the fusalage
Itsnot to bad for the first covering job for me. next time I will make a fiberglass cowl that comes off if it takes all winter. |
I read the site your link led the way to........it looks really nice , my only question is does the engine get hot? I can't see any way for the air to escape.
I've not tried it, so I can't comment from experience. I'm just thinking about making something similar if/when I decide on a 4* or Venture 60.
Bear in mind that the cowl slopes inward from the original fusalage so that on a side mounted engine there will be a fair amount of the cylinder still in the airflow. Probably more than with a fully enclosed fiberglass cowl... Also, the muffler is out in the open too... |
Personally, I'd glass the outside of the balsa cowl and buy paint that matches your covering of choice. They make matching paint for Monokote and Ultracote.
Dennis- |
Although I'm no expert with Monokote, I had no problem covering the balsa cowl on my Venture 60 with one piece of Monokote. Here's a picture...
1 Attachment(s)
So, here's the picture I tried to post last time. (I hope I do it right this time!)
Redford, Beautiful job. Any problems with engine overheating?
1 Attachment(s)
Nope. Enough of it hangs out the right side that overheating is now problem.
Here's a picture of that side, which is less pretty, but functional. |
That was, of course, heating is NO problem, not NOW a problem.
FYI everyone, bigger, better pictures are here
Dave, how did you manage to get around those compound curves with just one piece of monokote? |
Thanks, sure looks pretty......I guess I gotta give it a try.
There are actually only three sides to it (since the right side is mostly open). Start with the Monokote on the middle side and pull it around!
| All times are GMT -8. The time now is 11:46 AM. |
