RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   JR XP-7202 mode1 to mode 2 conversion (https://www.rcuniverse.com/forum/tips-techniques-180/8412887-jr-xp-7202-mode1-mode-2-conversion.html)
RCEEBUILDER 01-28-2009 05:39 PM
1 Attachment(s)
I have purchased a JR XP7202 Mode 1. I thought I can change the mode . Oh nooo this version can not be convertible . Firm upgrade is needed to convert this. No problem let's open the box.. there are 6 philips screws to be loosen.
RCEEBUILDER 01-28-2009 05:52 PM
RE: JR XP-7202 mode1 to mode 2 conversion
1 Attachment(s)
it looks so nice..New pictures coming soon .
422nd_novak1 01-29-2009 06:19 AM
Hello! iam curious if you did it well! could you changed it to mode 2? Some say that it need a firmware update to do it...I have the same radio and im up to change it too.
Regards
Novak
RCEEBUILDER 01-29-2009 05:55 PM
1 Attachment(s)
Conversion still in progress. After removal of sender pcb power pcb has been removed too. Then left and right stick holders have been removed . Now it is time to interchange throttle and elevator trim and pot . Before the installation we have to change the cables too.
RCEEBUILDER 01-29-2009 06:53 PM
1 Attachment(s)
Now it is time to assemble all the things again .
RCEEBUILDER 02-01-2009 04:43 AM
1 Attachment(s)
and finally
karambochomdls 02-21-2009 06:49 PM
Hi, i did it but the trims still working like before, ive changed the cables like You said but still the same. Radio Thr trim is now display elev trim and radio elev trim is display thr trim. How can i resolve this? how can i make it work changing all of the cables? Thanks
RCEEBUILDER 02-28-2009 06:12 PM
ORIGINAL: karambochomdls
Logically it is imposibble that the trims are working as before if you have really interchange the cables. Trims on the display will remain same as before. Never mind it.
tigrejohn 03-01-2009 01:22 AM
Have a silly question. Wouldn't it have been easier just to switch the rudder and aileron servo connections at the receiver?
RCEEBUILDER 03-01-2009 07:17 PM
:) Simply can not be done . Since this is sophisticated transmitter mix functions will not work. Moreover throttle and elevator trims work different .Throttle trim is only actived when the stick below the middle point .
caffinatedbear 03-10-2009 10:52 PM
PM Sent to RC builder to thank and to ask for clarification on wire cut change and resoldering.
Let me thank you publicly as well!
Caffinatedbear
Sleepy bears are grumpy!
RCEEBUILDER 03-11-2009 03:34 AM
1 Attachment(s)
Dear Caffinatedbear
As you can see below 4 cables should be cut and resoldered for each channel . In other words 4 cables for elevator , 4 cables for throttle.
caffinatedbear 03-22-2009 01:28 AM
Can you explain a bit more about the trim working after this conversion. You say that trims on the display will remain as before. so I just set up the trims properly looking at the mechanics of the heli and never mind the display? . Thanks
RCEEBUILDER 03-26-2009 02:33 AM
After conversion trims work properly. With the conversion , only the polarity of the trims and sticks have been changed. No problem at all If you do not take care the trims on the display.
karambochomdls 03-26-2009 11:38 AM
It Works OK! Thanks
dematel 05-05-2009 11:05 AM
I have a question for you. Those 4 wires do I have to solder throttle wires to the place where elevator wires where? Thanks Marcel
I did conversion from mode 2 to mode 1 :-)
dematel 05-05-2009 11:15 AM
I think I understand it know. I see the arrows now. Thanks
