Fabric Covering Sticker and graphics removal
Hello all, I have a bipe that I just bought, It is covered with a fabric covering { unknown type} and has several stripes and stickers glued to the fabric is there a way to remove these from the surface without damaging the fabric ? Its pretty ugly right now and I guess I can recover if ness. just dont want to at this time:eek:....Thanks
RE: Fabric Covering Sticker and graphics removal
you might try lighter fluid to disolve the glue of the stickers, test a area of the paint first to make sure it wont distroy your paint
I was given a plane covered in In and Out stickers, I used my heat gun to soften the glue then peeled them off. Some types of stickers you can rub on some acetone with a rag and give it a couple of minutes for the glue to soften then peel. Good luck with your mess!!;)
ORIGINAL: RuninWideOpen Hello all, I have a bipe that I just bought, It is covered with a fabric covering { unknown type} and has several stripes and stickers glued to the fabric is there a way to remove these from the surface without damaging the fabric ? Its pretty ugly right now and I guess I can recover if ness. just dont want to at this time:eek:....Thanks Just go slow and experiment. Good luck, Bill |
Light heat to loosen, then WD 40 to remove the residue.
Walt |
| All times are GMT -8. The time now is 01:22 PM. |
