RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   COCKPIT COAMING MATERIAL (https://www.rcuniverse.com/forum/tips-techniques-180/9133373-cockpit-coaming-material.html)
Dai Phan 09-29-2009 01:44 PM
Hello folks,
I tried to use fuel line tubing but I could not cut a line straight enough so it looks really bad. Short of buying what is offering on market, what else can I use? I will use this on a park flyer WW1 Fokker DVII. Thanks DP
Wilson4824 09-29-2009 01:56 PM
RE: COCKPIT COAMING MATERIAL
1 Attachment(s)
I have the Fokker D7 from Great planes. I used a windshield washer tubing from NAPA. It cost me all of 2 bucks.
Then I took a block a wood and drilled a whole the same size OD as the tubing.. then glue an #11 blade to the block so it would split the tube in open. ran the tube through the block pressto.. the tube is split up. Then with some clear silcone i had just glued to the plane.
not sure if you can see it this picture.
ro347 09-29-2009 02:04 PM
Great thinking on the block!!!
w8ye 09-29-2009 09:56 PM
I buy it from Tower already split
http://www3.towerhobbies.com/cgi-bin...&search=Go
dignlivn 09-29-2009 10:28 PM
1 Attachment(s)
Windshield washer tubing too.
I pin it down after stretching it
a bit. Then use my trust # 11
blade.
Bob
combatpigg 09-30-2009 12:05 AM
Super glue sticks to latex tubing as good as skin. Sig carries 1/8" ID latex and the fishing tackle shops carry various sizes, even in black.
w8ye 09-30-2009 12:17 AM
I used canopy glue and it has held up for years
Dai Phan 09-30-2009 12:16 PM
Hi,
I went to auto part stores and the smallest size is 3/32" which is too big on my GP Fokker DVII (park flyers). Anywhere else I can find the size half that? DP
Dai Phan 09-30-2009 12:17 PM
ORIGINAL: Wilson4824
That looks to be the right size of the tubing. What size is that please? DP
dignlivn 09-30-2009 09:55 PM
1 Attachment(s)
ORIGINAL: Dai Phan
Hope you are not cutting the Tubing in half ?
Just one slit lenght wise is what you want.
Bob
Wilson4824 09-30-2009 10:21 PM
Yea Bob I use the blade with block tool just to split the tube open.
I go to NAPA go to the bulk hose section.. It my store... NAPA DAN keeps it behind the counter. I have used some 1/8th If you cant find it a NAPA you might check some place that sells air tools/ airbrush supplies.
